Time Before: 0.00206 seconds
Time After: 0.00264 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00272 seconds
Time After: 0.00322 seconds
Time Before: 0.00352 seconds
Time After: 0.00367 seconds
Time Before: 0.00452 seconds
Time After: 0.00751 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00375 seconds
Time After: 0.01197 seconds
Time Taken: 0.00822 seconds
Time Before: 0.01392 seconds
Time After: 0.01431 seconds
Time Before: 0.01677 seconds
Time After: 0.01795 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01338 seconds
Time After: 0.01813 seconds
Time Taken: 0.00475 seconds
Memory After: 2,261.703 KB
Time Before: 0.02339 seconds
Time After: 0.02353 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02575 seconds
Time After: 0.02704 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.028666019439697
Time Before: 0.02976 seconds
Time After: 0.03001 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03193 seconds
Time After: 0.03335 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=110227', badlocation = 1
Time Before: 0.04556 seconds
Time After: 0.04581 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.044675827026367 seconds with 9 queries, spending 0.0085597038269043 doing MySQL queries and 0.036116123199463 doing PHP things.
