Time Before: 0.01623 seconds
Time After: 0.02539 seconds
Time Taken: 0.00917 seconds
Time Before: 0.02553 seconds
Time After: 0.02602 seconds
Time Before: 0.02626 seconds
Time After: 0.02643 seconds
Time Before: 0.02734 seconds
Time After: 0.02958 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02653 seconds
Time After: 0.03373 seconds
Time Taken: 0.00720 seconds
Time Before: 0.04365 seconds
Time After: 0.04408 seconds
Time Before: 0.04573 seconds
Time After: 0.05035 seconds
Time Taken: 0.00462 seconds
Time Before: 0.04292 seconds
Time After: 0.05063 seconds
Time Taken: 0.00770 seconds
Time Before: 0.07915 seconds
Time After: 0.07932 seconds
Time Before: 0.10073 seconds
Time After: 0.10196 seconds
Time Before: 0.10999 seconds
Time After: 0.11014 seconds
Time Before: 0.11268 seconds
Time After: 0.11410 seconds
UPDATE session SET lastactivity = 1776551076, location = '/forums/private.php?do=newpm&explain=1&u=110252' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.13330 seconds
Time After: 0.13388 seconds
Time Taken: 0.00058 seconds
