Time Before: 0.00177 seconds
Time After: 0.00270 seconds
Time Taken: 0.00093 seconds
Time Before: 0.00281 seconds
Time After: 0.00362 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00387 seconds
Time After: 0.00406 seconds
Time Before: 0.00474 seconds
Time After: 0.00723 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00411 seconds
Time After: 0.01211 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01389 seconds
Time After: 0.01407 seconds
Time Before: 0.01661 seconds
Time After: 0.01838 seconds
Time Taken: 0.00177 seconds
Time Before: 0.01333 seconds
Time After: 0.01866 seconds
Time Taken: 0.00532 seconds
Time Before: 0.02393 seconds
Time After: 0.02412 seconds
Time Before: 0.02587 seconds
Time After: 0.02749 seconds
Time Taken: 0.00162 seconds
Time Before: 0.03162 seconds
Time After: 0.03177 seconds
Time Before: 0.03463 seconds
Time After: 0.03611 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110257', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05312 seconds
Time After: 0.05340 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
