Time Before: 0.01774 seconds
Time After: 0.02213 seconds
Time Taken: 0.00439 seconds
Time Before: 0.02222 seconds
Time After: 0.02263 seconds
Time Before: 0.02285 seconds
Time After: 0.02297 seconds
Time Before: 0.02383 seconds
Time After: 0.02599 seconds
Time Taken: 0.00215 seconds
Time Before: 0.02302 seconds
Time After: 0.03022 seconds
Time Taken: 0.00720 seconds
Time Before: 0.03718 seconds
Time After: 0.03768 seconds
Time Before: 0.03917 seconds
Time After: 0.04040 seconds
Time Before: 0.03639 seconds
Time After: 0.04061 seconds
Time Taken: 0.00422 seconds
Time Before: 0.06331 seconds
Time After: 0.06345 seconds
Time Before: 0.07755 seconds
Time After: 0.07880 seconds
Time Before: 0.08866 seconds
Time After: 0.08882 seconds
Time Before: 0.09161 seconds
Time After: 0.09310 seconds
UPDATE session SET lastactivity = 1776789060, location = '/forums/private.php?do=newpm&explain=1&u=110289' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.11117 seconds
Time After: 0.11189 seconds
Time Taken: 0.00072 seconds
