Time Before: 0.00604 seconds
Time After: 0.00850 seconds
Time Taken: 0.00247 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00860 seconds
Time After: 0.00906 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00929 seconds
Time After: 0.00946 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01032 seconds
Time After: 0.01265 seconds
Time Taken: 0.00232 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00953 seconds
Time After: 0.01704 seconds
Time Taken: 0.00751 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.02200 seconds
Time After: 0.02243 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.02505 seconds
Time After: 0.02630 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.02120 seconds
Time After: 0.02653 seconds
Time Taken: 0.00533 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.04566 seconds
Time After: 0.04583 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.05295 seconds
Time After: 0.05444 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.06141 seconds
Time After: 0.06160 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.06444 seconds
Time After: 0.06638 seconds
Time Taken: 0.00193 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110330' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.08462 seconds
Time After: 0.08495 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
