Time Before: 0.00215 seconds
Time After: 0.00268 seconds
Time Before: 0.00275 seconds
Time After: 0.00313 seconds
Time Before: 0.00335 seconds
Time After: 0.00347 seconds
Time Before: 0.00416 seconds
Time After: 0.00670 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00352 seconds
Time After: 0.01061 seconds
Time Taken: 0.00709 seconds
Time Before: 0.01321 seconds
Time After: 0.01358 seconds
Time Before: 0.01614 seconds
Time After: 0.01741 seconds
Time Before: 0.01239 seconds
Time After: 0.01765 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02658 seconds
Time After: 0.02673 seconds
Time Before: 0.02968 seconds
Time After: 0.03118 seconds
Time Taken: 0.00151 seconds
End call of global.php: 0.032835960388184
Time Before: 0.03504 seconds
Time After: 0.03534 seconds
Time Before: 0.03745 seconds
Time After: 0.03893 seconds
SET lastactivity = 1788931345, location = '/forums/private.php?do=newpm&explain=1&u=110367'
Time Before: 0.05374 seconds
Time After: 0.05425 seconds
Page generated in 0.052819013595581 seconds with 9 queries, spending 0.0086367130279541 doing MySQL queries and 0.044182300567627 doing PHP things.
