Time Before: 0.01845 seconds
Time After: 0.02260 seconds
Time Taken: 0.00414 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02268 seconds
Time After: 0.02318 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02350 seconds
Time After: 0.02364 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02435 seconds
Time After: 0.02721 seconds
Time Taken: 0.00286 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02371 seconds
Time After: 0.03132 seconds
Time Taken: 0.00761 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03804 seconds
Time After: 0.03849 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04096 seconds
Time After: 0.04215 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03737 seconds
Time After: 0.04237 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.07616 seconds
Time After: 0.07634 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.12012 seconds
Time After: 0.12148 seconds
Time Taken: 0.00136 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.14881 seconds
Time After: 0.14895 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.15392 seconds
Time After: 0.15535 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110411', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.18125 seconds
Time After: 0.18152 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
