Time Before: 0.00211 seconds
Time After: 0.00281 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00292 seconds
Time After: 0.00362 seconds
Time Before: 0.00386 seconds
Time After: 0.00402 seconds
Time Before: 0.00477 seconds
Time After: 0.00745 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00407 seconds
Time After: 0.01088 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01278 seconds
Time After: 0.01316 seconds
Time Before: 0.01545 seconds
Time After: 0.01733 seconds
Time Taken: 0.00188 seconds
Time Before: 0.01217 seconds
Time After: 0.01751 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02244 seconds
Time After: 0.02266 seconds
Time Before: 0.02478 seconds
Time After: 0.02602 seconds
End call of global.php: 0.027652978897095
Time Before: 0.02889 seconds
Time After: 0.02904 seconds
Time Before: 0.03103 seconds
Time After: 0.03257 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=110429', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04550 seconds
Time After: 0.05334 seconds
Time Taken: 0.00784 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.044576168060303 seconds with 9 queries, spending 0.01678204536438 doing MySQL queries and 0.027794122695923 doing PHP things.
