Time Before: 0.03640 seconds
Time After: 0.04548 seconds
Time Taken: 0.00908 seconds
Time Before: 0.04557 seconds
Time After: 0.04593 seconds
Time Before: 0.04615 seconds
Time After: 0.04627 seconds
Time Before: 0.04705 seconds
Time After: 0.04903 seconds
Time Taken: 0.00198 seconds
Time Before: 0.04633 seconds
Time After: 0.05300 seconds
Time Taken: 0.00667 seconds
Time Before: 0.06294 seconds
Time After: 0.06331 seconds
Time Before: 0.06589 seconds
Time After: 0.06707 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06230 seconds
Time After: 0.06725 seconds
Time Taken: 0.00494 seconds
Memory After: 2,261.820 KB
Time Before: 0.12401 seconds
Time After: 0.12412 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.15375 seconds
Time After: 0.15523 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.16821 seconds
Time After: 0.16863 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.17110 seconds
Time After: 0.17253 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788984968, location = '/forums/private.php?do=newpm&explain=1&u=110432', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.19491 seconds
Time After: 0.19523 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
