Time Before: 0.01281 seconds
Time After: 0.01806 seconds
Time Taken: 0.00525 seconds
Time Before: 0.01817 seconds
Time After: 0.01861 seconds
Time Before: 0.01884 seconds
Time After: 0.01939 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02070 seconds
Time After: 0.02357 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01945 seconds
Time After: 0.02751 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03545 seconds
Time After: 0.03587 seconds
Time Before: 0.03925 seconds
Time After: 0.04100 seconds
Time Taken: 0.00175 seconds
Time Before: 0.03464 seconds
Time After: 0.04123 seconds
Time Taken: 0.00659 seconds
Time Before: 0.06072 seconds
Time After: 0.06084 seconds
Time Before: 0.07486 seconds
Time After: 0.07617 seconds
Time Taken: 0.00131 seconds
Time Before: 0.08338 seconds
Time After: 0.08353 seconds
Time Before: 0.08581 seconds
Time After: 0.08726 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110471', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.10275 seconds
Time After: 0.10309 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
