Time Before: 0.01038 seconds
Time After: 0.01294 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01303 seconds
Time After: 0.01343 seconds
Time Before: 0.01365 seconds
Time After: 0.01382 seconds
Time Before: 0.01478 seconds
Time After: 0.01717 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01388 seconds
Time After: 0.02125 seconds
Time Taken: 0.00737 seconds
Time Before: 0.02669 seconds
Time After: 0.02686 seconds
Time Before: 0.02934 seconds
Time After: 0.03048 seconds
Time Taken: 0.00114 seconds
Time Before: 0.02615 seconds
Time After: 0.03065 seconds
Time Taken: 0.00450 seconds
Time Before: 0.05030 seconds
Time After: 0.05043 seconds
Time Before: 0.06091 seconds
Time After: 0.06215 seconds
End call of global.php: 0.064136028289795
Time Before: 0.06920 seconds
Time After: 0.06938 seconds
Time Before: 0.07158 seconds
Time After: 0.07307 seconds
SET lastactivity = 1776532189, location = '/forums/private.php?do=newpm&explain=1&u=110478'
Time Before: 0.08907 seconds
Time After: 0.08939 seconds
Page generated in 0.088156938552856 seconds with 9 queries, spending 0.0076110363006592 doing MySQL queries and 0.080545902252197 doing PHP things.
