Time Before: 0.00149 seconds
Time After: 0.00203 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00210 seconds
Time After: 0.00254 seconds
Time Before: 0.00276 seconds
Time After: 0.00291 seconds
Time Before: 0.00357 seconds
Time After: 0.00589 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00295 seconds
Time After: 0.00928 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01098 seconds
Time After: 0.01138 seconds
Time Before: 0.01263 seconds
Time After: 0.01381 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01042 seconds
Time After: 0.01398 seconds
Time Taken: 0.00355 seconds
Time Before: 0.01878 seconds
Time After: 0.01890 seconds
Time Before: 0.02063 seconds
Time After: 0.02188 seconds
End call of global.php: 0.023459911346436
Time Before: 0.02465 seconds
Time After: 0.02480 seconds
Time Before: 0.02690 seconds
Time After: 0.02838 seconds
SET lastactivity = 1773271951, location = '/forums/private.php?do=newpm&explain=1&u=110493'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04348 seconds
Time After: 0.04382 seconds
Page generated in 0.042582988739014 seconds with 9 queries, spending 0.007828950881958 doing MySQL queries and 0.034754037857056 doing PHP things.
