Time Before: 0.02441 seconds
Time After: 0.03220 seconds
Time Taken: 0.00779 seconds
Time Before: 0.03228 seconds
Time After: 0.03265 seconds
Time Before: 0.03287 seconds
Time After: 0.03299 seconds
Time Before: 0.03375 seconds
Time After: 0.03595 seconds
Time Taken: 0.00220 seconds
Time Before: 0.03305 seconds
Time After: 0.03986 seconds
Time Taken: 0.00681 seconds
Time Before: 0.05047 seconds
Time After: 0.05089 seconds
Time Before: 0.05347 seconds
Time After: 0.05469 seconds
Time Before: 0.04979 seconds
Time After: 0.05490 seconds
Time Taken: 0.00511 seconds
Time Before: 0.09239 seconds
Time After: 0.09253 seconds
Time Before: 0.11122 seconds
Time After: 0.11254 seconds
Time Taken: 0.00131 seconds
Time Before: 0.12509 seconds
Time After: 0.12523 seconds
Time Before: 0.12749 seconds
Time After: 0.12892 seconds
UPDATE session SET lastactivity = 1782921431, location = '/forums/private.php?do=newpm&explain=1&u=110497', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.14547 seconds
Time After: 0.14574 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
