Time Before: 0.02024 seconds
Time After: 0.02751 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02762 seconds
Time After: 0.02814 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02840 seconds
Time After: 0.02859 seconds
Time Before: 0.02935 seconds
Time After: 0.03166 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02864 seconds
Time After: 0.03565 seconds
Time Taken: 0.00700 seconds
Time Before: 0.04748 seconds
Time After: 0.04790 seconds
Time Before: 0.04936 seconds
Time After: 0.05053 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04679 seconds
Time After: 0.05075 seconds
Time Taken: 0.00396 seconds
Time Before: 0.07948 seconds
Time After: 0.07964 seconds
Time Before: 0.10146 seconds
Time After: 0.10295 seconds
End call of global.php: 0.10512709617615
Time Before: 0.11217 seconds
Time After: 0.11244 seconds
Time Before: 0.11501 seconds
Time After: 0.11650 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=110513'
Time Before: 0.13422 seconds
Time After: 0.13453 seconds
Page generated in 0.13318800926208 seconds with 9 queries, spending 0.0083298683166504 doing MySQL queries and 0.12485814094543 doing PHP things.
