Time Before: 0.00141 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00237 seconds
Time Before: 0.00286 seconds
Time After: 0.00323 seconds
Time Before: 0.00436 seconds
Time After: 0.00706 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00331 seconds
Time After: 0.01195 seconds
Time Taken: 0.00864 seconds
Time Before: 0.01431 seconds
Time After: 0.01476 seconds
Time Before: 0.01812 seconds
Time After: 0.01935 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01351 seconds
Time After: 0.01961 seconds
Time Taken: 0.00610 seconds
Memory After: 2,261.820 KB
Time Before: 0.02758 seconds
Time After: 0.02774 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02982 seconds
Time After: 0.03110 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.033446073532104
Time Before: 0.03477 seconds
Time After: 0.03493 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03715 seconds
Time After: 0.03859 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788955215, location = '/forums/private.php?do=newpm&explain=1&u=110521'
Time Before: 0.05144 seconds
Time After: 0.05170 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.050467967987061 seconds with 9 queries, spending 0.0084912776947021 doing MySQL queries and 0.041976690292358 doing PHP things.
