Time Before: 0.00248 seconds
Time After: 0.00311 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00318 seconds
Time After: 0.00381 seconds
Time Before: 0.00412 seconds
Time After: 0.00422 seconds
Time Before: 0.00490 seconds
Time After: 0.00776 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00427 seconds
Time After: 0.01118 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01326 seconds
Time After: 0.01374 seconds
Time Before: 0.01607 seconds
Time After: 0.01740 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01262 seconds
Time After: 0.01757 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02285 seconds
Time After: 0.02307 seconds
Time Before: 0.02512 seconds
Time After: 0.02638 seconds
Time Before: 0.02935 seconds
Time After: 0.02960 seconds
Time Before: 0.03197 seconds
Time After: 0.03367 seconds
Time Taken: 0.00170 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110541' WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.04597 seconds
Time After: 0.04642 seconds
