Time Before: 0.02797 seconds
Time After: 0.03372 seconds
Time Taken: 0.00575 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03382 seconds
Time After: 0.03417 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03444 seconds
Time After: 0.03462 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03532 seconds
Time After: 0.03896 seconds
Time Taken: 0.00365 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03469 seconds
Time After: 0.04356 seconds
Time Taken: 0.00887 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05439 seconds
Time After: 0.05513 seconds
Time Taken: 0.00074 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05673 seconds
Time After: 0.05788 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.05309 seconds
Time After: 0.05806 seconds
Time Taken: 0.00498 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.07998 seconds
Time After: 0.08016 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10069 seconds
Time After: 0.10193 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.11456 seconds
Time After: 0.11472 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.11682 seconds
Time After: 0.11823 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1776672159, location = '/forums/private.php?do=newpm&explain=1&u=110564', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.13649 seconds
Time After: 0.13672 seconds
Memory Before: 4,296.195 KB
Memory After: 4,296.406 KB
