Time Before: 0.00136 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00252 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00275 seconds
Time After: 0.00288 seconds
Time Before: 0.00361 seconds
Time After: 0.00597 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00293 seconds
Time After: 0.00933 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01118 seconds
Time After: 0.01138 seconds
Time Before: 0.01388 seconds
Time After: 0.01514 seconds
Time Before: 0.01062 seconds
Time After: 0.01531 seconds
Time Taken: 0.00470 seconds
Time Before: 0.02019 seconds
Time After: 0.02034 seconds
Time Before: 0.02220 seconds
Time After: 0.02343 seconds
End call of global.php: 0.025017976760864
Time Before: 0.02658 seconds
Time After: 0.02673 seconds
Time Before: 0.02866 seconds
Time After: 0.03008 seconds
SET lastactivity = 1783087653, location = '/forums/private.php?do=newpm&explain=1&u=110590', badlocation = 1
Time Before: 0.04547 seconds
Time After: 0.04585 seconds
Page generated in 0.044551849365234 seconds with 9 queries, spending 0.0078849792480469 doing MySQL queries and 0.036666870117188 doing PHP things.
