Time Before: 0.01983 seconds
Time After: 0.03141 seconds
Time Taken: 0.01158 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03153 seconds
Time After: 0.03229 seconds
Time Taken: 0.00076 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03253 seconds
Time After: 0.03265 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03338 seconds
Time After: 0.03580 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03273 seconds
Time After: 0.03974 seconds
Time Taken: 0.00702 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04607 seconds
Time After: 0.04633 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04899 seconds
Time After: 0.05026 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04546 seconds
Time After: 0.05045 seconds
Time Taken: 0.00499 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.08871 seconds
Time After: 0.08885 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.23453 seconds
Time After: 0.23580 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.27327 seconds
Time After: 0.27342 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.27788 seconds
Time After: 0.27938 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110607', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.30223 seconds
Time After: 0.30255 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
