Time Before: 0.01012 seconds
Time After: 0.01240 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01250 seconds
Time After: 0.01305 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01333 seconds
Time After: 0.01348 seconds
Time Before: 0.01456 seconds
Time After: 0.01715 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01356 seconds
Time After: 0.02143 seconds
Time Taken: 0.00787 seconds
Time Before: 0.02428 seconds
Time After: 0.02465 seconds
Time Before: 0.02714 seconds
Time After: 0.02843 seconds
Time Before: 0.02363 seconds
Time After: 0.02862 seconds
Time Taken: 0.00499 seconds
Time Before: 0.04676 seconds
Time After: 0.04687 seconds
Time Before: 0.05444 seconds
Time After: 0.05568 seconds
End call of global.php: 0.057671070098877
Time Before: 0.06256 seconds
Time After: 0.06269 seconds
Time Before: 0.06483 seconds
Time After: 0.06625 seconds
SET lastactivity = 1785315895, location = '/forums/private.php?do=newpm&explain=1&u=110680', badlocation = 1
Time Before: 0.08286 seconds
Time After: 0.08323 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.081730127334595 seconds with 9 queries, spending 0.0082292556762695 doing MySQL queries and 0.073500871658325 doing PHP things.
