Time Before: 0.00161 seconds
Time After: 0.00232 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00239 seconds
Time After: 0.00284 seconds
Time Before: 0.00306 seconds
Time After: 0.00324 seconds
Time Before: 0.00389 seconds
Time After: 0.00595 seconds
Time Taken: 0.00206 seconds
Time Before: 0.00328 seconds
Time After: 0.00940 seconds
Time Taken: 0.00612 seconds
Time Before: 0.01125 seconds
Time After: 0.01188 seconds
Time Taken: 0.00062 seconds
Time Before: 0.01440 seconds
Time After: 0.01559 seconds
Time Before: 0.01057 seconds
Time After: 0.01577 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02088 seconds
Time After: 0.02104 seconds
Time Before: 0.02278 seconds
Time After: 0.02402 seconds
End call of global.php: 0.025634050369263
Time Before: 0.02670 seconds
Time After: 0.02687 seconds
Time Before: 0.02887 seconds
Time After: 0.03032 seconds
SET lastactivity = 1784739198, location = '/forums/private.php?do=newpm&explain=1&u=110696', badlocation = 1
Time Before: 0.04261 seconds
Time After: 0.04298 seconds
Page generated in 0.041700839996338 seconds with 9 queries, spending 0.007887601852417 doing MySQL queries and 0.033813238143921 doing PHP things.
