Time Before: 0.01660 seconds
Time After: 0.02274 seconds
Time Taken: 0.00615 seconds
Time Before: 0.02283 seconds
Time After: 0.02327 seconds
Time Before: 0.02348 seconds
Time After: 0.02362 seconds
Time Before: 0.02435 seconds
Time After: 0.02678 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02368 seconds
Time After: 0.03097 seconds
Time Taken: 0.00729 seconds
Time Before: 0.04054 seconds
Time After: 0.04095 seconds
Time Before: 0.04239 seconds
Time After: 0.04359 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03979 seconds
Time After: 0.04383 seconds
Time Taken: 0.00404 seconds
Memory After: 2,261.703 KB
Time Before: 0.06283 seconds
Time After: 0.06298 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08334 seconds
Time After: 0.08471 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09685 seconds
Time After: 0.09699 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09935 seconds
Time After: 0.10136 seconds
Time Taken: 0.00201 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110702' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11884 seconds
Time After: 0.11925 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
