Time Before: 0.00784 seconds
Time After: 0.01087 seconds
Time Taken: 0.00303 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.01097 seconds
Time After: 0.01152 seconds
Time Taken: 0.00055 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.01176 seconds
Time After: 0.01190 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.01263 seconds
Time After: 0.01497 seconds
Time Taken: 0.00234 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.01195 seconds
Time After: 0.01937 seconds
Time Taken: 0.00742 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.02435 seconds
Time After: 0.02457 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.02710 seconds
Time After: 0.02833 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.02360 seconds
Time After: 0.02865 seconds
Time Taken: 0.00504 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.04504 seconds
Time After: 0.04520 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.05590 seconds
Time After: 0.05713 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
Time Before: 0.06235 seconds
Time After: 0.06251 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.06490 seconds
Time After: 0.06639 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
UPDATE session SET lastactivity = 1785321278, location = '/forums/private.php?do=newpm&explain=1&u=110740' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08333 seconds
Time After: 0.08363 seconds
Memory Before: 4,299.156 KB
Memory After: 4,299.383 KB
