Time Before: 0.00501 seconds
Time After: 0.00651 seconds
Time Taken: 0.00150 seconds
Time Before: 0.00661 seconds
Time After: 0.00708 seconds
Time Before: 0.00733 seconds
Time After: 0.00750 seconds
Time Before: 0.00827 seconds
Time After: 0.01055 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00756 seconds
Time After: 0.01634 seconds
Time Taken: 0.00878 seconds
Time Before: 0.01904 seconds
Time After: 0.01950 seconds
Time Before: 0.02288 seconds
Time After: 0.02420 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01813 seconds
Time After: 0.02450 seconds
Time Taken: 0.00637 seconds
Time Before: 0.03060 seconds
Time After: 0.03076 seconds
Time Before: 0.03305 seconds
Time After: 0.03432 seconds
Time Before: 0.03949 seconds
Time After: 0.04221 seconds
Time Taken: 0.00273 seconds
Time Before: 0.04540 seconds
Time After: 0.04692 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1783141167, location = '/forums/private.php?do=newpm&explain=1&u=110760' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.06578 seconds
Time After: 0.06616 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
