Time Before: 0.00194 seconds
Time After: 0.00273 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00326 seconds
Time After: 0.00399 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00447 seconds
Time After: 0.00464 seconds
Time Before: 0.00553 seconds
Time After: 0.00805 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00472 seconds
Time After: 0.01466 seconds
Time Taken: 0.00994 seconds
Time Before: 0.01767 seconds
Time After: 0.01788 seconds
Time Before: 0.02029 seconds
Time After: 0.02158 seconds
Time Before: 0.01709 seconds
Time After: 0.02184 seconds
Time Taken: 0.00475 seconds
Time Before: 0.03128 seconds
Time After: 0.03151 seconds
Time Before: 0.03578 seconds
Time After: 0.03715 seconds
Time Taken: 0.00138 seconds
Time Before: 0.04171 seconds
Time After: 0.04188 seconds
Time Before: 0.04426 seconds
Time After: 0.04725 seconds
Time Taken: 0.00298 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110773', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.06167 seconds
Time After: 0.06197 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
