Time Before: 0.01865 seconds
Time After: 0.02785 seconds
Time Taken: 0.00920 seconds
Time Before: 0.02796 seconds
Time After: 0.02837 seconds
Time Before: 0.02862 seconds
Time After: 0.02879 seconds
Time Before: 0.02971 seconds
Time After: 0.03194 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02886 seconds
Time After: 0.03587 seconds
Time Taken: 0.00701 seconds
Time Before: 0.04437 seconds
Time After: 0.04480 seconds
Time Before: 0.04823 seconds
Time After: 0.04948 seconds
Time Before: 0.04372 seconds
Time After: 0.04970 seconds
Time Taken: 0.00598 seconds
Time Before: 0.08967 seconds
Time After: 0.08984 seconds
Time Before: 0.10916 seconds
Time After: 0.11046 seconds
End call of global.php: 0.11254096031189
Time Before: 0.12132 seconds
Time After: 0.12150 seconds
Time Before: 0.12400 seconds
Time After: 0.12550 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1776540923, location = '/forums/private.php?do=newpm&explain=1&u=110793', badlocation = 1
Time Before: 0.14207 seconds
Time After: 0.14248 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.14115810394287 seconds with 9 queries, spending 0.0080468654632568 doing MySQL queries and 0.13311123847961 doing PHP things.
