Time Before: 0.00207 seconds
Time After: 0.00264 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00275 seconds
Time After: 0.00339 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00369 seconds
Time After: 0.00384 seconds
Time Before: 0.00469 seconds
Time After: 0.00759 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00389 seconds
Time After: 0.01180 seconds
Time Taken: 0.00791 seconds
Time Before: 0.01400 seconds
Time After: 0.01438 seconds
Time Before: 0.01696 seconds
Time After: 0.01817 seconds
Time Before: 0.01337 seconds
Time After: 0.01835 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02338 seconds
Time After: 0.02357 seconds
Time Before: 0.02562 seconds
Time After: 0.02737 seconds
Time Taken: 0.00174 seconds
Time Before: 0.03067 seconds
Time After: 0.03103 seconds
Time Before: 0.03319 seconds
Time After: 0.03468 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1789142679, location = '/forums/private.php?do=newpm&explain=1&u=110798' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04796 seconds
Time After: 0.04831 seconds
