Time Before: 0.03357 seconds
Time After: 0.04154 seconds
Time Taken: 0.00797 seconds
Time Before: 0.04166 seconds
Time After: 0.04207 seconds
Time Before: 0.04232 seconds
Time After: 0.04250 seconds
Time Before: 0.04338 seconds
Time After: 0.04604 seconds
Time Taken: 0.00266 seconds
Time Before: 0.04257 seconds
Time After: 0.05012 seconds
Time Taken: 0.00755 seconds
Time Before: 0.06183 seconds
Time After: 0.06231 seconds
Time Before: 0.06567 seconds
Time After: 0.06749 seconds
Time Taken: 0.00183 seconds
Time Before: 0.06112 seconds
Time After: 0.06774 seconds
Time Taken: 0.00662 seconds
Time Before: 0.12213 seconds
Time After: 0.12229 seconds
Time Before: 0.15236 seconds
Time After: 0.15364 seconds
Time Before: 0.16835 seconds
Time After: 0.16852 seconds
Time Before: 0.17104 seconds
Time After: 0.17248 seconds
UPDATE session SET lastactivity = 1785292186, location = '/forums/private.php?do=newpm&explain=1&u=110863', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.18995 seconds
Time After: 0.19023 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
