Time Before: 0.01261 seconds
Time After: 0.01621 seconds
Time Taken: 0.00360 seconds
Time Before: 0.01632 seconds
Time After: 0.01678 seconds
Time Before: 0.01707 seconds
Time After: 0.01721 seconds
Time Before: 0.01820 seconds
Time After: 0.02067 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01729 seconds
Time After: 0.02539 seconds
Time Taken: 0.00811 seconds
Time Before: 0.03113 seconds
Time After: 0.03161 seconds
Time Before: 0.03412 seconds
Time After: 0.03529 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03040 seconds
Time After: 0.03550 seconds
Time Taken: 0.00510 seconds
Time Before: 0.05493 seconds
Time After: 0.05507 seconds
Time Before: 0.06411 seconds
Time After: 0.06543 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.068341970443726
Time Before: 0.07426 seconds
Time After: 0.07446 seconds
Time Before: 0.07737 seconds
Time After: 0.07883 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=110944', badlocation = 1
Time Before: 0.09662 seconds
Time After: 0.09687 seconds
Page generated in 0.095412969589233 seconds with 9 queries, spending 0.0080950260162354 doing MySQL queries and 0.087317943572998 doing PHP things.
