Time Before: 0.00145 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00238 seconds
Time Before: 0.00258 seconds
Time After: 0.00272 seconds
Time Before: 0.00344 seconds
Time After: 0.00570 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00277 seconds
Time After: 0.01094 seconds
Time Taken: 0.00817 seconds
Time Before: 0.01415 seconds
Time After: 0.01456 seconds
Time Before: 0.01630 seconds
Time After: 0.01749 seconds
Time Before: 0.01330 seconds
Time After: 0.01778 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02669 seconds
Time After: 0.02693 seconds
Time Before: 0.03000 seconds
Time After: 0.03130 seconds
End call of global.php: 0.033570051193237
Time Before: 0.03509 seconds
Time After: 0.03524 seconds
Time Before: 0.03815 seconds
Time After: 0.03962 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111007', badlocation = 1
Time Before: 0.05671 seconds
Time After: 0.05702 seconds
Page generated in 0.055766105651855 seconds with 9 queries, spending 0.0078368186950684 doing MySQL queries and 0.047929286956787 doing PHP things.
