Time Before: 0.00443 seconds
Time After: 0.00661 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00669 seconds
Time After: 0.00707 seconds
Time Before: 0.00726 seconds
Time After: 0.00736 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00803 seconds
Time After: 0.00993 seconds
Time Taken: 0.00190 seconds
Time Before: 0.00742 seconds
Time After: 0.01458 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01779 seconds
Time After: 0.01812 seconds
Time Before: 0.02059 seconds
Time After: 0.02199 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01715 seconds
Time After: 0.02221 seconds
Time Taken: 0.00507 seconds
Time Before: 0.03512 seconds
Time After: 0.03525 seconds
Time Before: 0.04039 seconds
Time After: 0.04172 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.044667959213257
Time Before: 0.04726 seconds
Time After: 0.04768 seconds
Time Before: 0.05013 seconds
Time After: 0.05155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111008'
Time Before: 0.06664 seconds
Time After: 0.06692 seconds
Page generated in 0.065340995788574 seconds with 9 queries, spending 0.0076901912689209 doing MySQL queries and 0.057650804519653 doing PHP things.
