Time Before: 0.00278 seconds
Time After: 0.00354 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00365 seconds
Time After: 0.00410 seconds
Time Before: 0.00436 seconds
Time After: 0.00449 seconds
Time Before: 0.00530 seconds
Time After: 0.00805 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00457 seconds
Time After: 0.01273 seconds
Time Taken: 0.00816 seconds
Time Before: 0.01606 seconds
Time After: 0.01646 seconds
Time Before: 0.01905 seconds
Time After: 0.02021 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01538 seconds
Time After: 0.02045 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.703 KB
Time Before: 0.03002 seconds
Time After: 0.03015 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03479 seconds
Time After: 0.03605 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.038477897644043
Time Before: 0.04066 seconds
Time After: 0.04082 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04409 seconds
Time After: 0.04558 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=111039', badlocation = 1
Time Before: 0.06258 seconds
Time After: 0.06279 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.061613082885742 seconds with 9 queries, spending 0.0081605911254883 doing MySQL queries and 0.053452491760254 doing PHP things.
