Time Before: 0.00700 seconds
Time After: 0.00953 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00961 seconds
Time After: 0.01023 seconds
Time Taken: 0.00062 seconds
Time Before: 0.01049 seconds
Time After: 0.01064 seconds
Time Before: 0.01139 seconds
Time After: 0.01378 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01071 seconds
Time After: 0.01770 seconds
Time Taken: 0.00699 seconds
Time Before: 0.02214 seconds
Time After: 0.02257 seconds
Time Before: 0.02517 seconds
Time After: 0.02641 seconds
Time Before: 0.02138 seconds
Time After: 0.02664 seconds
Time Taken: 0.00526 seconds
Time Before: 0.04193 seconds
Time After: 0.04207 seconds
Time Before: 0.04937 seconds
Time After: 0.05062 seconds
Time Before: 0.05890 seconds
Time After: 0.05917 seconds
Time Before: 0.06232 seconds
Time After: 0.06375 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111042' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.08048 seconds
Time After: 0.08081 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
