Time Before: 0.00167 seconds
Time After: 0.00228 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00235 seconds
Time After: 0.00313 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00338 seconds
Time After: 0.00352 seconds
Time Before: 0.00424 seconds
Time After: 0.00739 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00357 seconds
Time After: 0.01090 seconds
Time Taken: 0.00733 seconds
Time Before: 0.01310 seconds
Time After: 0.01331 seconds
Time Before: 0.01597 seconds
Time After: 0.01719 seconds
Time Before: 0.01249 seconds
Time After: 0.01738 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02267 seconds
Time After: 0.02279 seconds
Time Before: 0.02463 seconds
Time After: 0.02584 seconds
Time Before: 0.02928 seconds
Time After: 0.02945 seconds
Time Before: 0.03214 seconds
Time After: 0.03360 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111083', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04649 seconds
Time After: 0.04680 seconds
