Time Before: 0.00154 seconds
Time After: 0.00202 seconds
Time Before: 0.00209 seconds
Time After: 0.00251 seconds
Time Before: 0.00286 seconds
Time After: 0.00306 seconds
Time Before: 0.00402 seconds
Time After: 0.00685 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00314 seconds
Time After: 0.01229 seconds
Time Taken: 0.00915 seconds
Time Before: 0.01470 seconds
Time After: 0.01513 seconds
Time Before: 0.01838 seconds
Time After: 0.01957 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01390 seconds
Time After: 0.01984 seconds
Time Taken: 0.00594 seconds
Time Before: 0.02737 seconds
Time After: 0.02752 seconds
Time Before: 0.03009 seconds
Time After: 0.03136 seconds
Time Before: 0.03663 seconds
Time After: 0.03682 seconds
Time Before: 0.03972 seconds
Time After: 0.04114 seconds
UPDATE session SET lastactivity = 1785374654, location = '/forums/private.php?do=newpm&explain=1&u=111096' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05433 seconds
Time After: 0.05464 seconds
