Time Before: 0.00133 seconds
Time After: 0.00178 seconds
Time Before: 0.00184 seconds
Time After: 0.00244 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00265 seconds
Time After: 0.00274 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00342 seconds
Time After: 0.00562 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00279 seconds
Time After: 0.00901 seconds
Time Taken: 0.00622 seconds
Time Before: 0.01103 seconds
Time After: 0.01148 seconds
Time Before: 0.01409 seconds
Time After: 0.01525 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01044 seconds
Time After: 0.01542 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02044 seconds
Time After: 0.02058 seconds
Time Before: 0.02235 seconds
Time After: 0.02360 seconds
Time Before: 0.02684 seconds
Time After: 0.02698 seconds
Time Before: 0.02910 seconds
Time After: 0.03055 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111098' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04337 seconds
Time After: 0.04374 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
