Time Before: 0.01738 seconds
Time After: 0.02730 seconds
Time Taken: 0.00992 seconds
Time Before: 0.02741 seconds
Time After: 0.02782 seconds
Time Before: 0.02812 seconds
Time After: 0.02825 seconds
Time Before: 0.02901 seconds
Time After: 0.03131 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02831 seconds
Time After: 0.03570 seconds
Time Taken: 0.00739 seconds
Time Before: 0.04321 seconds
Time After: 0.04363 seconds
Time Before: 0.04668 seconds
Time After: 0.04837 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04247 seconds
Time After: 0.04859 seconds
Time Taken: 0.00611 seconds
Memory After: 2,261.703 KB
Time Before: 0.07873 seconds
Time After: 0.07886 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09662 seconds
Time After: 0.09790 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10882 seconds
Time After: 0.10899 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11184 seconds
Time After: 0.11333 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111147' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13690 seconds
Time After: 0.13731 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
