Time Before: 0.02594 seconds
Time After: 0.03719 seconds
Time Taken: 0.01126 seconds
Time Before: 0.03733 seconds
Time After: 0.03834 seconds
Time Taken: 0.00101 seconds
Time Before: 0.03880 seconds
Time After: 0.03892 seconds
Time Before: 0.03991 seconds
Time After: 0.04238 seconds
Time Taken: 0.00247 seconds
Time Before: 0.03901 seconds
Time After: 0.04747 seconds
Time Taken: 0.00846 seconds
Memory After: 1,642.430 KB
Memory Used: 1,081.023 KB
Time Before: 0.05815 seconds
Time After: 0.05843 seconds
Memory Before: 2,137.359 KB
Memory After: 2,137.977 KB
Time Before: 0.06098 seconds
Time After: 0.06226 seconds
Memory Before: 2,149.539 KB
Memory After: 2,149.398 KB
Time Before: 0.05740 seconds
Time After: 0.06247 seconds
Time Taken: 0.00507 seconds
Memory Before: 2,129.539 KB
Memory After: 2,262.438 KB
Memory Used: 132.898 KB
Time Before: 0.09479 seconds
Time After: 0.09500 seconds
Memory Before: 2,815.945 KB
Memory After: 2,816.461 KB
Time Before: 0.11631 seconds
Time After: 0.11759 seconds
Memory Before: 2,904.164 KB
Memory After: 2,904.758 KB
Time Before: 0.12888 seconds
Time After: 0.12909 seconds
Memory Before: 3,540.984 KB
Memory After: 3,541.414 KB
Time Before: 0.13226 seconds
Time After: 0.13421 seconds
Time Taken: 0.00195 seconds
Memory Before: 3,822.563 KB
Memory After: 3,824.250 KB
UPDATE session SET lastactivity = 1776532812, location = '/forums/private.php?do=newpm&explain=1&u=111169', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.15546 seconds
Time After: 0.15578 seconds
Memory Before: 4,289.313 KB
Memory After: 4,289.523 KB
