Time Before: 0.00542 seconds
Time After: 0.00774 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00784 seconds
Time After: 0.00829 seconds
Time Before: 0.00853 seconds
Time After: 0.00866 seconds
Time Before: 0.00940 seconds
Time After: 0.01169 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00871 seconds
Time After: 0.01635 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02168 seconds
Time After: 0.02206 seconds
Time Before: 0.02465 seconds
Time After: 0.02583 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02103 seconds
Time After: 0.02603 seconds
Time Taken: 0.00500 seconds
Memory After: 2,261.820 KB
Time Before: 0.03773 seconds
Time After: 0.03791 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.04948 seconds
Time After: 0.05076 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.052970170974731
Time Before: 0.05607 seconds
Time After: 0.05625 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.05918 seconds
Time After: 0.06117 seconds
Time Taken: 0.00199 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789092930, location = '/forums/private.php?do=newpm&explain=1&u=111171', badlocation = 1
Time Before: 0.07780 seconds
Time After: 0.07811 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.076647996902466 seconds with 9 queries, spending 0.0083627700805664 doing MySQL queries and 0.068285226821899 doing PHP things.
