Time Before: 0.00210 seconds
Time After: 0.00281 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00291 seconds
Time After: 0.00356 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00382 seconds
Time After: 0.00397 seconds
Time Before: 0.00466 seconds
Time After: 0.00707 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00402 seconds
Time After: 0.01041 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01270 seconds
Time After: 0.01309 seconds
Time Before: 0.01569 seconds
Time After: 0.01687 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01206 seconds
Time After: 0.01704 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.703 KB
Time Before: 0.02196 seconds
Time After: 0.02211 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02397 seconds
Time After: 0.02521 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.026782035827637
Time Before: 0.02858 seconds
Time After: 0.02905 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03096 seconds
Time After: 0.03237 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=111199'
Time Before: 0.04440 seconds
Time After: 0.04468 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.043524980545044 seconds with 9 queries, spending 0.0083432197570801 doing MySQL queries and 0.035181760787964 doing PHP things.
