Time Before: 0.00894 seconds
Time After: 0.01280 seconds
Time Taken: 0.00386 seconds
Time Before: 0.01287 seconds
Time After: 0.01324 seconds
Time Before: 0.01347 seconds
Time After: 0.01360 seconds
Time Before: 0.01431 seconds
Time After: 0.01650 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01365 seconds
Time After: 0.02184 seconds
Time Taken: 0.00819 seconds
Time Before: 0.02724 seconds
Time After: 0.02760 seconds
Time Before: 0.03019 seconds
Time After: 0.03137 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02631 seconds
Time After: 0.03164 seconds
Time Taken: 0.00532 seconds
Time Before: 0.04917 seconds
Time After: 0.04958 seconds
Time Before: 0.05803 seconds
Time After: 0.05955 seconds
Time Taken: 0.00152 seconds
Time Before: 0.06585 seconds
Time After: 0.06603 seconds
Time Before: 0.06851 seconds
Time After: 0.07000 seconds
UPDATE session SET lastactivity = 1776478135, location = '/forums/private.php?do=newpm&explain=1&u=111206', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.08888 seconds
Time After: 0.08915 seconds
