Time Before: 0.00925 seconds
Time After: 0.01164 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01172 seconds
Time After: 0.01213 seconds
Time Before: 0.01245 seconds
Time After: 0.01259 seconds
Time Before: 0.01340 seconds
Time After: 0.01593 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01265 seconds
Time After: 0.02045 seconds
Time Taken: 0.00780 seconds
Time Before: 0.02517 seconds
Time After: 0.02554 seconds
Time Before: 0.02834 seconds
Time After: 0.02953 seconds
Time Before: 0.02452 seconds
Time After: 0.02975 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04990 seconds
Time After: 0.05007 seconds
Time Before: 0.05779 seconds
Time After: 0.05905 seconds
Time Before: 0.06495 seconds
Time After: 0.06509 seconds
Time Before: 0.06755 seconds
Time After: 0.06898 seconds
UPDATE session SET lastactivity = 1788916884, location = '/forums/private.php?do=newpm&explain=1&u=111209' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08561 seconds
Time After: 0.08592 seconds
