Time Before: 0.01547 seconds
Time After: 0.02127 seconds
Time Taken: 0.00580 seconds
Time Before: 0.02140 seconds
Time After: 0.02189 seconds
Time Before: 0.02215 seconds
Time After: 0.02228 seconds
Time Before: 0.02300 seconds
Time After: 0.02537 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02236 seconds
Time After: 0.02978 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03693 seconds
Time After: 0.03717 seconds
Time Before: 0.03954 seconds
Time After: 0.04074 seconds
Time Before: 0.03623 seconds
Time After: 0.04099 seconds
Time Taken: 0.00476 seconds
Time Before: 0.06631 seconds
Time After: 0.06658 seconds
Time Before: 0.07579 seconds
Time After: 0.07706 seconds
End call of global.php: 0.079524993896484
Time Before: 0.08404 seconds
Time After: 0.08420 seconds
Time Before: 0.08687 seconds
Time After: 0.08881 seconds
Time Taken: 0.00194 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111245'
Time Before: 0.11022 seconds
Time After: 0.11046 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.10914611816406 seconds with 9 queries, spending 0.0083177089691162 doing MySQL queries and 0.10082840919495 doing PHP things.
