Time Before: 0.02711 seconds
Time After: 0.03329 seconds
Time Taken: 0.00618 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03341 seconds
Time After: 0.03382 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03408 seconds
Time After: 0.03425 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03514 seconds
Time After: 0.03828 seconds
Time Taken: 0.00314 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03433 seconds
Time After: 0.04276 seconds
Time Taken: 0.00844 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05186 seconds
Time After: 0.05231 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05475 seconds
Time After: 0.05600 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.05117 seconds
Time After: 0.05618 seconds
Time Taken: 0.00501 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.10482 seconds
Time After: 0.10501 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12662 seconds
Time After: 0.12784 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.13941 seconds
Time After: 0.13957 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.14226 seconds
Time After: 0.14389 seconds
Time Taken: 0.00163 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1780594270, location = '/forums/private.php?do=newpm&explain=1&u=111256' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.16628 seconds
Time After: 0.16661 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
