Time Before: 0.00205 seconds
Time After: 0.00260 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00267 seconds
Time After: 0.00316 seconds
Time Before: 0.00337 seconds
Time After: 0.00349 seconds
Time Before: 0.00437 seconds
Time After: 0.00660 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00354 seconds
Time After: 0.01002 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01312 seconds
Time After: 0.01399 seconds
Time Taken: 0.00087 seconds
Time Before: 0.01724 seconds
Time After: 0.01847 seconds
Time Before: 0.01178 seconds
Time After: 0.01868 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02496 seconds
Time After: 0.02508 seconds
Time Before: 0.02702 seconds
Time After: 0.02915 seconds
Time Taken: 0.00214 seconds
Time Before: 0.03358 seconds
Time After: 0.03374 seconds
Time Before: 0.03671 seconds
Time After: 0.03815 seconds
UPDATE session SET lastactivity = 1789104952, location = '/forums/private.php?do=newpm&explain=1&u=111295' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05186 seconds
Time After: 0.05231 seconds
