Time Before: 0.00211 seconds
Time After: 0.00282 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00292 seconds
Time After: 0.00332 seconds
Time Before: 0.00368 seconds
Time After: 0.00387 seconds
Time Before: 0.00475 seconds
Time After: 0.00760 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00395 seconds
Time After: 0.01285 seconds
Time Taken: 0.00890 seconds
Time Before: 0.01514 seconds
Time After: 0.01558 seconds
Time Before: 0.01822 seconds
Time After: 0.01940 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01445 seconds
Time After: 0.01958 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02481 seconds
Time After: 0.02495 seconds
Time Before: 0.02764 seconds
Time After: 0.02895 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.03161096572876
Time Before: 0.03316 seconds
Time After: 0.03337 seconds
Time Before: 0.03584 seconds
Time After: 0.03725 seconds
SET lastactivity = 1783466907, location = '/forums/private.php?do=newpm&explain=1&u=111305', badlocation = 1
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.04970 seconds
Time After: 0.05004 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.04878306388855 seconds with 9 queries, spending 0.0084679126739502 doing MySQL queries and 0.0403151512146 doing PHP things.
