Time Before: 0.01273 seconds
Time After: 0.01564 seconds
Time Taken: 0.00291 seconds
Time Before: 0.01574 seconds
Time After: 0.01617 seconds
Time Before: 0.01643 seconds
Time After: 0.01656 seconds
Time Before: 0.01740 seconds
Time After: 0.01981 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01661 seconds
Time After: 0.02514 seconds
Time Taken: 0.00853 seconds
Time Before: 0.03030 seconds
Time After: 0.03091 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03460 seconds
Time After: 0.03578 seconds
Time Before: 0.02952 seconds
Time After: 0.03599 seconds
Time Taken: 0.00648 seconds
Time Before: 0.05398 seconds
Time After: 0.05415 seconds
Time Before: 0.06360 seconds
Time After: 0.06485 seconds
End call of global.php: 0.066547870635986
Time Before: 0.06949 seconds
Time After: 0.06965 seconds
Time Before: 0.07192 seconds
Time After: 0.07341 seconds
SET lastactivity = 1785324801, location = '/forums/private.php?do=newpm&explain=1&u=111309', badlocation = 1
Time Before: 0.09096 seconds
Time After: 0.09126 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.089848041534424 seconds with 9 queries, spending 0.0081334114074707 doing MySQL queries and 0.081714630126953 doing PHP things.
