Time Before: 0.00865 seconds
Time After: 0.01218 seconds
Time Taken: 0.00353 seconds
Time Before: 0.01230 seconds
Time After: 0.01269 seconds
Time Before: 0.01295 seconds
Time After: 0.01312 seconds
Time Before: 0.01382 seconds
Time After: 0.01622 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01318 seconds
Time After: 0.02008 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02607 seconds
Time After: 0.02647 seconds
Time Before: 0.02936 seconds
Time After: 0.03055 seconds
Time Before: 0.02464 seconds
Time After: 0.03076 seconds
Time Taken: 0.00612 seconds
Time Before: 0.04910 seconds
Time After: 0.04946 seconds
Time Before: 0.05916 seconds
Time After: 0.06039 seconds
End call of global.php: 0.062076807022095
Time Before: 0.06589 seconds
Time After: 0.06625 seconds
Time Before: 0.06837 seconds
Time After: 0.06989 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111334', badlocation = 1
Time Before: 0.08803 seconds
Time After: 0.08830 seconds
Page generated in 0.086784839630127 seconds with 9 queries, spending 0.0083000659942627 doing MySQL queries and 0.078484773635864 doing PHP things.
