Time Before: 0.02230 seconds
Time After: 0.03318 seconds
Time Taken: 0.01088 seconds
Time Before: 0.03327 seconds
Time After: 0.03381 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03404 seconds
Time After: 0.03424 seconds
Time Before: 0.03574 seconds
Time After: 0.03814 seconds
Time Taken: 0.00240 seconds
Time Before: 0.03430 seconds
Time After: 0.04226 seconds
Time Taken: 0.00797 seconds
Time Before: 0.05551 seconds
Time After: 0.05575 seconds
Time Before: 0.05847 seconds
Time After: 0.05967 seconds
Time Before: 0.05484 seconds
Time After: 0.05991 seconds
Time Taken: 0.00507 seconds
Time Before: 0.10351 seconds
Time After: 0.10367 seconds
Time Before: 0.13006 seconds
Time After: 0.13131 seconds
Time Before: 0.14475 seconds
Time After: 0.14490 seconds
Time Before: 0.14799 seconds
Time After: 0.14950 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1776826818, location = '/forums/private.php?do=newpm&explain=1&u=111344' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.16683 seconds
Time After: 0.16729 seconds
