Time Before: 0.01367 seconds
Time After: 0.01688 seconds
Time Taken: 0.00321 seconds
Time Before: 0.01695 seconds
Time After: 0.01743 seconds
Time Before: 0.01770 seconds
Time After: 0.01786 seconds
Time Before: 0.01861 seconds
Time After: 0.02098 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01792 seconds
Time After: 0.02506 seconds
Time Taken: 0.00714 seconds
Time Before: 0.03036 seconds
Time After: 0.03085 seconds
Time Before: 0.03217 seconds
Time After: 0.03338 seconds
Time Before: 0.02953 seconds
Time After: 0.03357 seconds
Time Taken: 0.00404 seconds
Time Before: 0.05255 seconds
Time After: 0.05275 seconds
Time Before: 0.06302 seconds
Time After: 0.06430 seconds
Time Before: 0.07066 seconds
Time After: 0.07084 seconds
Time Before: 0.07357 seconds
Time After: 0.07505 seconds
UPDATE session SET lastactivity = 1782992468, location = '/forums/private.php?do=newpm&explain=1&u=111356' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.09626 seconds
Time After: 0.09652 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
